ZMF Ori's...phenomenally good!What headphones have you paired it with
ifI iCan Pro - Impressions & Discussion
- Thread starter grizzlybeast
dcguy73
Formerly known as dc_guy
Has anyone on this forum taken apart their iCan Pro? I found a video on YouTube that shows how to do it, but the guy in the video doesn't say what size torx he's using to do the disassembly. Thanks!
dcguy73
Never mind, figured it out.Has anyone on this forum taken apart their iCan Pro? I found a video on YouTube that shows how to do it, but the guy in the video doesn't say what size torx he's using to do the disassembly. Thanks!
dcguy73
iCan Pro case opened and tubes rolled. Sounds better already! A more linear sound with none of the original tubes' murky coloration (which is only apparent after hearing the amp with upgraded tubes).
I thought the 5670s were supposed to be the bees knees, no? What did you swap them with?
What about the pinout? I believe the 5670s have a swapped pin compared with their relative 6922.
dcguy73
Western Electric 2C51s are compatible with the pinout and are (so I'm told) iFi Audio's preferred tubes for use with the iCan Pro, but they're too rare for mass production, unlike the 5670s. I got them from an iFi audio dealer who uses them in his personal iCan Pro.
Skooks
So, how did you get into it? And, does that dealer have more of these tubes?Never mind, figured it out.
Thanks!
tonyo442
[QUOTE = "dcguy73, post: 14066087, member: 482877"] Les Western Electric 2C51s sont compatibles avec le brochage et sont (ainsi que je le dis) les tubes préférés d'iFi Audio pour l'iCan Pro, mais ils sont trop rares pour la production de masse, contrairement aux années 5670. Je les ai obtenus d'un revendeur audio iFi qui les utilise dans son iCan Pro personnel. [/ QUOTE]
bonjour, vous ne regrettez pas votre achat, les western sont assez chers,.....merci
dcguy73
ils ne sont pas aussi chers que les tubes Cca que j'ai achetés.
dcguy73
Thanks!
It's not that hard to take apart. You need size t15 and t20 torx wrenches. if you really want to do it, I'll PM you the directions.
The tubes came from Tim at Kitsune Hifi. I got them as part of a package deal. He usually only sells them with the purchase of a new iCan Pro, but you could always ask if he'd be willing to sell them to you separately or you could buy something else from his store.
dcguy73
duplicate post
tonyo442
[QUOTE = "dcguy73, post: 14066468, membre: 482877"] Ce n'est pas si difficile à démonter. Vous avez besoin de clés Torx de taille t15 et t20. Si vous voulez vraiment le faire, je vais vous PM les directions.
Les tubes venaient de Tim à Kitsune Hifi. Je les ai dans le cadre d'un forfait. Il ne les vend habituellement que pour l'achat d'un nouvel iCan Pro, mais vous pouvez toujours demander s'il serait prêt à vous les vendre séparément ou vous pourriez acheter quelque chose d'autre dans son magasin. [/ QUOTE]
merci,
merci,
merci,
merci,
tonyo442
[QUOTE = "tonyo442, post: 14066481, membre: 489344"] [QUOTE = "dcguy73, post: 14066468, membre: 482877"] Ce n'est pas difficile à démonter. Vous avez besoin de clés Torx de taille t15 et t20. Si vous voulez vraiment faire, je vais vous PM les directions.
Les tubes venaient de Tim à Kitsune Hifi. Je suis dans le cadre d'un forfait. Il ne vend pas que pour l'achat d'un nouvel iCan Pro, mais vous pouvez toujours demander s'il était prêt à vous vendre hors ou vous acheter quelque chose d'autre dans son magasin. [/ CITATION]
merci,
merci, [/ QUOTE]
sur Ebay il y en a,
merci,
merci, [/ QUOTE]
sur Ebay il y en a,
dcguy73
Yes, @tonyo442, they are available on eBay also.
I’d be grateful if you’d PM me too
Thanks for the info
