Starcruncher
- Aug 16, 2015
Now the price is back up to 1699 on Adorama. WTH? But happy I snuck into that deal.
Quite the sale price for the Pro iCan
http://www.adorama.com/ifproican.html?emailprice=t
$1299
Just purchased from Adorama and waiting for delivery.
Pardon my newbiness, and embarrassed to ask but any reason to use a separate DAC with this?
A DAC is in everything. It is what converts Digital to Analog so it can be audible. How the sound is converted to Analog makes a huge difference in the sound quality being heard. Some units, even more expensive than this amp, still have a somewhat digital sound to the conversion and make the music less natural.
The same way an amp can sound murky, bassy or bass light, midrange heavy or thin etc etc is the same way a DAC can sound and the built in DAC of your computer is not really good enough for an amp of this caliber or hardly any amp for that matter. My DAC is the most expensive part of my chain and the most important to me. I would never really know what the amp is capable of unless I have a good DAC to enable it.
You have to have some DAC to get the music into the amp to amplify it. The Pro iCan doesn't have a DAC.
If you have RCA or 3.5mm line out from your source, you can start with that and it will work (you just need the right cables). You can then borrow DACs to see what might work for you.
The iDSD is a good DAC, as is the Modi Multibit. Both area reasonably priced. Obviously there are others.
the DAC and Amp likely will be the electronics that affect your source the least, as long as you have a decent amp and a decent DAC. Decent can be as inexpensive as the iFi Nano line or the Modi/Magni. Headphones and source (lossless vs lossy) are the place to start, then Amp and DAC and then when you are complex insanely into this "hobby", cables. After cables, vibration control!
I think that's where I'm leaning as well. I ordered the same package from Adorama and get mine next week. Right now I have the Modi Multibit so I'll use that temporarily until the iDSD becomes available.
I was also considering the Holo Audio Spring DAC Level 3 but it's a little out of my price range and according toTim Connor from KitsuneHiFi it'll be to at least till the end of December before they're back in stock do their popularity.
Did your LCD-3s come in a "sealed" package? I ask because I may sell them cause I'm pretty satisfied with my HD800S & Ether C's. I also am waiting for the Massdrop HD6XX's HP's so I may just get rid of the LCDs and use that money on a DAC.
Thanks for the link.
