superuser1
I heard some news that ifi would be going the balanced way, so is there any talk of having any balanced outputs on this?
Actually, the expected power rating was not mentioned in this thread but elsewhere. Apologies! As far as BT, I can see from the pix that it has a pairing button but I can't see a BT on/off. But one can always switch the source device's BT off.
The Pictures look like Ifi will use the same "3.5mm TRRS with Balanced compatible wiring Port" like on the Nano iDSD BL.I heard some news that ifi would be going the balanced way, so is there any talk of having any balanced outputs on this?
Yeah, that would make sense, as does the suggestion that BT may be switched on and off by keeping the button pressed.The Pictures look like Ifi will use the same "3.5mm TRRS with Balanced compatible wiring Port" like on the Nano iDSD BL.
Disappointed to see the Apple CCK DONGLE in that one photo. Would like to see portables be Apple-ready. Oh well.
There you go, in the iFi Audio section: http://www.hifiplus.com/articles/ca...ort-from-ultimate-headphone-guide-part-three/By the way, you mentionend specs you found somewere elso. Do you mind posting a link to them?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I had no doubt, both work semlessly on my micro BL. Just wanted something smaller to carry around, was about to pull the trigger on a nano BL, then I saw this...BT is there for wireless connection, but there are regular alternatives; USB type A and coax/TOSLINK input as well.
Yes, but will you implement apossibility to turn off bluetooth to minimize interference? And finially, when can we expect the xDSD?BT is there for wireless connection, but there are regular alternatives; USB type A and coax/TOSLINK input as well.
Of course the BT antenna can be turned on/off, this is a standard in every device with multiple inputs. This is not a BT speaker.Yes, but will you implement apossibility to turn off bluetooth to minimize interference? And finially, when can we expect the xDSD?
