I'd question the use of Sabre Dac chips for DSD output, I think the best implementations for 'direct native DSD' processing via
TI/Burr Brown chipsets and chipless designs, http://www.positive-feedback.com/Issue78/dsd.htm
Chipless designs and the Burr Brown implementation are the same thing. Just, one is done via discrete parts, the other is on chip
Process is the same though.
Burr Brown implementation is outstanding, maybe the best? I haven't had the chance to hear some of the newer 1 bit discrete designs, such as Lampizator, the T+A, Holo Audio, and Miska's open source dac.
The reason the BB is so good is the outstanding time domain performance. 8 bit delay line, as opposed to others who are using a much, much longer delay line. The increase in taps means better frequency domain performance, at the expense of time domain. A workaround is to upsample to DSD256 or DSD512 on these DACs with lots of taps... time domain performance will increase as the speed of the signal increases. But there is no free lunch. This creates other issues, requires signal DSP, etc, which is probably NOT what you really want to do with DSD. (Many would disagree with that, though) Anyway, the 8 bit delay line, and unequally weighted grouping of the 64 bitswitches in all Burr Brown Native DSD dacs is an excellent implementation, and two decades after the venerable DSD1700 chip was introduced, is still a standard bearer. Of course, this is one of the primary reasons iFi uses this chip rather than ESS.
For those of you who aren't really familiar with what the ESS chipset does with DSD, here is my best stab at it. ESS actually keeps what really happens in the chip very, very close to the vest, protecting their intellectual property fiercely. Not even the confidential data sheet says very much! (Actually, data sheets for ANY dac out there don't say a whole lot, and often what they do say isn't exactly what is going on...) Anyway, again, here is my best stab at it based on what I have read and been told.
ESS does not convert DSD 'natively'. The closest thing to native conversion we have is applying a FIR filter in the analog domain, like I described above. That is it.
ESS doesn't filter DSD in the analog domain. When a 1- bit bitstream hits the ESS chip, it gets routed to an IIR filter. You can select the cutoff frequency for this filter (50khz, 60khz, 70khz,). The OUTPUT of this filter is no longer 1 bit DSD. The samples that come out are now multi-bit. (No this is NOT mult-bit delta sigma) Now, the filtering that is uses is a slow rolloff that extends up to around 1 mhz, if my memory is correct. So the sample rate is not decimated to any of the common PCM rates. Actually, it is probably a really good filter with excellent time domain characteristics. Essentially it is the digital version of the analog filter used in the Burr Brown chipset. The filter, and the fact that things are now multi-bit, is NOT the problem here. The problem is, when this is done in the analog domain, you are DONE! The DSD signal has been converted to analog. The problem is, with the ESS, after this filtering, you are JUST GETTING STARTED.
While the DSD signal is now in the intermediate format (I am guessing it also goes though a noise-shaper, so its a lower bit high sample rate signal) 32 bit volume control may or may not be applied, and the ASRC jitter eliminator is applied. Then after that, the signal is converted back to delta sigma in the Hyperstream multi-stream modulator. And then that is likely analog filtered, as well, for the final output.
So, what I am getting at, is the ESS chip does a LOT more with the DSD signal. Lots of DSP and conversions to get to an end result. The other way is much more simple. The signal is already in a state where a single analog filtering is all that is required for conversion.
NOW don't get me wrong here... the ESS way apparently sound very, very good! Which way is technically better doesn't really matter.. all that matters is what the listener is hearing. If it sounds great, so what! But, on paper, I just can't see the ESS way as being the better solution, and I can't see how you could call it native DSD conversion.
Anyway.... sorry about the long post... I AM indeed looking forward to the iDSD Pro DAC. Saving my pennies. On my must buy list!
