iFi Audio Pro iDSD discussion thread
- Thread starter JWahl
TooFrank
- Feb 17, 2017
Good that I asked then --- Many thanksHi I think you should select “Balance Selection” Not “Pair”
(Was a bit confusing to me, because when ordering "pair" 1 piece = 329, when ordering "balanced" 1 piece = 164, so have to order two
dericchan1
Yes I had to order 2 pc under “balanced” as well. CheersGood that I asked then --- Many thanks
(Was a bit confusing to me, because when ordering "pair" 1 piece = 329, when ordering "balanced" 1 piece = 164, so have to order two)
- Mar 20, 2013
Indeed and just to make it clear, each our Pro range device requires two tubes, thanks!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
TooFrank
- Feb 17, 2017
Just pulled the triggerYes I had to order 2 pc under “balanced” as well. Cheers
- Mar 20, 2013
Just pulled the trigger![]()
You'll be happy about these WE 396As, you'll see
dericchan1
Congrats!!! It honestly sounds like a different dac under the tube mode with these WE396A tubes, you won't be disappointed!!!Just pulled the trigger![]()
- Mar 20, 2013
Although we like our GE5670 JANs (they're superb for what they are!), we consider these WEs as a noticeable upgrade.
- Mar 20, 2013
Folks, about our micro iDSD Diablo X and xMEMs, please see these:
- Mar 20, 2013
...and our latest product, LAN iSilencer:
TooFrank
- Feb 17, 2017
So I got the WE tubes and managed to replace the GE. I assembled the Pro, turned it on, switched to tube mode and no sound whatsoever
It looks as if the tubes are glowing. What can I have done wrong? Tomorrow I will try to swap to the old tubes, to check whether they still works....
- Mar 20, 2013
So I got the WE tubes and managed to replace the GE. I assembled the Pro, turned it on, switched to tube mode and no sound whatsoeverIt looks as if the tubes are glowing. What can I have done wrong? Tomorrow I will try to swap to the old tubes, to check whether they still works....
By the looks of it, you did everything correct. Please install the original set and see if there's sound. If it is and with WE it's not, please let our support know about this: https://support.ifi-audio.com
I'll double-check with our team whether there are any known issues, but other users didn't report any issues upon inserting the same WE tube type you got.
dericchan1
I am sorry to hear that. They are working perfectly fine for me and sounding great as well. I am not sure what could be wrong.So I got the WE tubes and managed to replace the GE. I assembled the Pro, turned it on, switched to tube mode and no sound whatsoeverIt looks as if the tubes are glowing. What can I have done wrong? Tomorrow I will try to swap to the old tubes, to check whether they still works....
TooFrank
- Feb 17, 2017
Thanks - just did check. Couldn't wait until tomorrow. First I swapped left and right WE, still glowing, but no sound. Then I replaced them with the GEs - and it works as usual - phew. Thought I might have damaged something. Conclusion: the WEs seem to be faulty and I will have to contact TAD....By the looks of it, you did everything correct. Please install the original set and see if there's sound. If it is and with WE it's not, please let our support know about this: https://support.ifi-audio.com
dericchan1
That's great to know its to do with the tubes. And its unacceptable for them to charge a hefty premium on proper matching, noise, leak, gas check but did not make sure there was actually issues with them!!!Thanks - just did check. Couldn't wait until tomorrow. First I swapped left and right WE, still glowing, but no sound. Then I replaced them with the GEs - and it works as usual - phew. Thought I might have damaged something. Conclusion: the WEs seem to be faulty and I will have to contact TAD....
Total: 8 (members: 0, guests: 8)
