iFi Audio Pro iDSD discussion thread
Discussion in 'Dedicated Source Components' started by jwahl, Jan 26, 2014.
105 106 107 108 109 110 111 112 113 114
116 117 118 119 120 121 122 123 124 125
  1. Tom Blake
    That's on their rack though which is not out yet. It looks to provide a bit more breathing space between each component vs direct stacking. Not sure how much heat the iESL generates but would be nice to know if iCAN can be directly stacked on top, especially since it has that solid anti-vibration pad on the bottom. Hopefully the scalloped top of the Pro series components provide enough ventilation for direct stacking.
  2. etc6849
    So it will absolutely be released in the US before say 10/2017?
    I love your products, and am thinking about reordering the iCan Pro as I loved it before, just couldn't justify it without a matching DAC and I wasn't sure when/if it would come. I still want this combo, and sold my Oppo HA-1, and so it's time for an upgrade.
  3. iFi audio
    To be shown with Sennheiser Orpheus HE-1 is a reason for us to be proud, hence we'll just leave the proof here...
    [​IMG]
    [​IMG]
    [​IMG]
    iFi audio Stay updated on iFi audio at their sponsor page on Head-Fi.
    https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
    h1f1add1cted likes this.
  4. h1f1add1cted
    Would the Pro iESL could run the Sennheiser HE-1 or did you tried that too? Or it's just possible to use the Sennheiser "special HE-1 amp"?
  5. Roen
    Can It drive a Shure KSE1500? 230V Bias Voltage from the 6-pin port, vs. 200V Bias Voltage Requirements from the KSE1500
  6. Slim1970
    On the iESL webpage it lists the Orpheus as one of the headphones that it can drive.
    http://ifi-audio.com/portfolio-view/pro-iesl/
  7. Trogdor
  8. iFi audio
    Thanks!
  9. Fastnbulbous
    So it's been a month since the iESL was released. Are we still looking at September for the iDSD?
  10. iFi audio
    We don't have any details regarding date, but rest assured that the product is in the pipeline.
    alphanumerix1 likes this.
  11. m-i-c-k-e-y
    So why the delay? You changed DAC chips/design?
  12. iFi audio
    Simply because we want it to be as great as possible. This project is too important for us to rush it and it's far too late to do any significant changes at this point. We're tweaking things constantly and it's a very time consuming thing to do.
    alphanumerix1, bidn and m-i-c-k-e-y like this.
  13. Tom Blake
    @iFi audio - I found the following Jan 2015 post from you earlier in this thread. Is the plan outlined still the same for clock synchronization features on the Pro iDSD? I am considering some SOtM products that have clock sync capabilities and it would be nice to know for future planning if the Pro iDSD could benefit. Thanks!
    ..."1) External Clock Synchronisation
    The iDSD Pro will allow the use of external clocks for USB and AES/EBU modes.
    Options available are the use of the BNC socket as 10MHz atomic clock input (this affects all clocks and inputs).
    For external sync either Wordclock via BNC or AES3 on the XLR input are supported. Finally the BNC can be configured as wordclock out (to make one iDSD Pro the "master" in a multi channel playback setup).
    The wordclock synchronisation is mainly for professional use, but will also allow the iDSD to be used in multichannel playback at home, as for this all DACs MUST be synchronised.
    The ability to add an external atomic (or other low-jitter) clock will cater to those who like to tweak their setups to the limit, as it replaces the internal crystal clock reference directly."
  14. iFi audio
    Let us just say that we'll return to the iDSD Pro topic soon and everything - every tasty detail people here might be interested in - will be revealed then.
  15. Esprit
    Jan 26, 2014 THREAD STARTER Post #1 of 1724
    [...] Elephants have a longer pregnancy than any other mammal—almost 22 months[...]
