- Mar 20, 2013
Two years after purchasing, initially not all that impressed with the performance of the iTube2 from memory now a distinct increase in distortion. Maybe it wasn't burned in properly, every now and again, the iTube2 was resurrected but it didn't work out. Never mind, last night I watched the TechMoan video on the Chifi buffer tube amp. The presenter was gushing over the sound of the warmth of tubes, so why not give the iTube2 another shot.
The iTube2 was wired in the unbalanced tape loop, and couldn't program it for 0db buffering, had to switch to 9db pre-amp mode to match levels correctly. Rest of the settings were 'flat'. The iPower 15V supply was used. Once the levels were the same (by ear) on HD800S, there was a shift in the sound stage when listening to the digital chain. After a few attempts on different material, conformed the difference in the sound stage, but at 2230 it was not practical to launch the speakers to find out how the sound stage changed. Tonality was not much in it, but was obscured by that image problem.
Playing Michael Jackson's Thriller (EPIC - ES 38112 from 1999) which has great sound stage depth and height on speakers, the differences were readily apparent. The height of vocals dropped some 150mm, and the depth affected, but couldn't judge that accurately, but very noticeable in a direct A/B. I'm not sure if different cables will help, there's timing problems here that some cables could fix, but hazard a guess, they would be more than the iTube2 costs. With the iTube2 surface temperature around 30C , currently is placed on a coffee coaster from ceramics. In the winter it's not so bad, but summer would be a different situation.
Not a fan of the iPower supply, having replaced it with a linear supply for the micro3 USB with great results, thinking is the timing between channels could improve and therefore the image could be closer to the 'original'. Will dig out an alternative supply and give it a shot.
Later report:
OK, changed the iPower to a variable DC bench (SMPS) supply, some 5A, 1mV ripple set for 15V. Well the height was returned, but the image, very strange now. Vocals in the middle, and everything else left or right, so where's the music from centre to left, and centre to right...? Just gone. So with a 'real' linear supply, it's possible to return the missing information, but to be confirmed. for those wish to know in pre-amp mode, current draw is 400 mA at 15 V. ifi advise that the itube2 can run from a 12V supply probably 500 mA.
I feel there's already too much effort to discover how to wring out the best out of the iTube2. If anyone wishes to take this further, a linear supply like a Keces, Teddy Pardo, Acopian would be one way forward. Icing on the cake would be 'classier' interconnects from the Nordost Blue Heaven family, or the red Wireworld types would bring some extra results to discover that extra piece of info. The PSU and the cables are a significant cost, but if these are already about, then have a shot.
Gear:
Supermicro Win2016, Roon, JCAT Net Femto Ethernet card
Lumin U1
Accuphase DC-950 DAC
Accuphase C-2420 Pre-amp
Accuphase AL-10 interconnects
Accuphase P-4200 Power amp
KEF 205/2 speakers
Sennheiser HD800S
Thanks for your feedback!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
