JKDJedi
I'll find out today. Just an experiment.What USB dual adapter have you bought. Link please. This might not be at all what you think.
OK, that's not an adapter. That's a USB Hub!Well, I now theoretically have 4 iGalvanic ports to choose from, IT WORKS. The Topping D30 is a new animal now..amazing. added depth and the low end extends.. love this product. I haven't tested out leaving both DACS powered on yet. Not sure if leaving both of them on would draw an excess of current through the iGalvanic, runs warm as is with just one on. So one at a time for now. Cool beans!!
Let it bake in for a day, my clicking went away after some burn in,Hi iFi Audio
I get clicks/pops if the ground link switch is in the middle position. Same problem (clicks/pops) if the switch is in the bottom position. No problem if the switch is in the top position.
Is the above indicative of no earth? Is it no earth on my notebook or no earth on my DAC?
Appreciate a reply so that I can try to add earth and use the ground link switch in the middle position which is optimal.
Thanks,
Leon
Buffer settings( and/or usb streaming mode), what dac are you using?Thanks but I had used it for months...
The optimal position of the switch is the one that works. It's different for different systems.Hi iFi Audio
Thanks,
Leon
Thanks for pointing this out. I used to have this control panel app, but I had to do a reinstall of my system, and I decided not to re-install the supplied driver, since Windows 10 provided the same driver. However, this meant I not longer have this control panel app.
By combing the USB regeneration circuitry with a low noise power supply, IsoGround and even despite lacking galvanic isolation, iFi's iUSB 3.0 micro offered a comprehensive solution to USB's main problems; ground loops, power quality and signal integrity.
That's it for now, but stay tuned, there's more!
Do you have measurements of iFi Galvanic vs Saec SUI-01SX?
The iFi Galvanic does a tremendous job for computer related usb issues. I cannot go without this unit now that I know what a true black background really is.The Saec is an ancient device--released in 2011--which does not even support USB2.0 high-speed (480Mbps), only 12Mbps. Based on one of the many $2 full-speed isolator chips. So no comparison whatsoever to devices like the iFi iGalvanic--or our own ISO REGEN.
