If we can only rip CD to 16bit/44.1KHZ flac, how do we get higher than 16bit/44.1KHZ file?
Mar 5, 2011 at 12:21 AM Thread Starter Post #1 of 9
Uncledan
Maybe it is newbie question for many people here, since I am totally new to computer audio.
Anyway, I finally start my new project to rip all my collection into digital format (flac), I am using dBpoweramp CD Ripper to do the job for me.  No matter I put in CD, HDCD, XRCD, SACD and DVD-Audio, I am only end up getting 16bit/44.1KHZ  flac file.  If it is the best we can get, how do other people get the 24/92KHZ file? are 24/92KHZ file only available to purchase online store like Linn Record?  And why all people want to get a DAC which can read 88.2, 96, 176.4, 192 kHz at up to 24 Bits file?  Since the most we can get from CD are 16bit/44.1KHZ flac.
Am I missing something? Thanks!!
Mar 5, 2011 at 1:38 AM Post #2 of 9
wav format allows you to rip to that. But I see it pointless unless getting the file from vinyl. And if you rip it to 32/192 or 32/98 the file size becomes 300mb for a 3-4minute song. I find that ridiculous. The file takes 1000% more space for a minute difference in SQ, not worth it to me unless you have multiple external hard drives composed of multi-teras each.
Mar 5, 2011 at 2:50 AM Post #3 of 9
"CD quality" is only 16/44.1.  For high-res recordings, they are either recorded or re-mastered from the original analog tapes at a higher resolution.
Mar 5, 2011 at 9:45 AM Post #4 of 9
SACD and DVD-A are better than 16/44.1 but have DRM.  As far as I know the only way to "rip" these at higher quality is to sample the analog output (similar to what you would do with vinyl)
Mar 5, 2011 at 10:17 AM Post #5 of 9
Hmm... are there some options in CD Ripper for FLAC encoder you have not set?
jiiteepee
Mar 5, 2011 at 1:46 PM Post #6 of 9
jiiteepee
Yes, maybe I am missing something, therefore I would like to do it the right method instead of redo the ripping later.  If I only have the normal DVD-rom and dBpoweramp CD Ripper, is it the best quality I can get is the CD layer of the HDCD, XRCD, SACD and DVD-Audio into 16bit/441.KHZ flac file?
Mar 5, 2011 at 3:09 PM Post #7 of 9
SACD you can only rip the CD layer, unless you record from analogue output.
XRCD is simply a better mastering process, the audio is still 44/16.
HDCD encodes up to 20 bit, but by ripping the CD you keep the HDCD encoding, and can decode it on playback (for example using foobar2k).
DVD-Audio can be demuxed with this, as long as its not encrypted or watermarked, I believe. Decrypting it seems like it's a complicated process, google it.
Mar 5, 2011 at 4:22 PM Post #8 of 9
Thanks for your quick answer.  I am wondering how do people get the higher 44/16 file?  Are they only availble online purchase?
Mar 5, 2011 at 4:51 PM Post #9 of 9
Bingo,
You download them. Here's a few places...
http://aixrecords.com/
http://bluecoastrecords.com/
http://www.cantaloupemusic.com/
http://www.computeraudiophile.com/
http://www.musicgiants.com/musicgiants/index.html
https://www.hdtracks.com/ (FREE SAMPLE HERE and one made just for us headphone people https://www.hdtracks.com/index.php?file=catalogdetail&valbum_code=HD666666666666)
http://hiresmusic.com/homepage.html
http://highdeftapetransfers.com/storefront.php
http://www.2l.no/hires/
http://www.itrax.com/
http://www.linnrecords.com/index.aspx
http://referencerecordings.com/
http://www.rhino.com/
http://bowers-wilkins.com/display.aspx?infid=3550
http://chesky.com/
