if I fell in love with AKG271, which is the next upgrade? AKG701?
Nov 18, 2008 at 3:49 PM Post #18 of 25
Originally Posted by XSAlliN /img/forum/go_quote.gif
Was that a joke?
That's same as K271 with Valour Pads and integrated cable. It's enough to buy Valour Pads and K271 is superior with detachable cable.
Exactly, do not confuse K271S with K171S
Nov 18, 2008 at 8:53 PM Post #20 of 25
.... but ... still confused ....
1) ad2000 is not available here in Italy
2) you told me that 701 sound much different....
So I repeat again the question: if you had the ag271, which is the closest upgrade that is worth?
If not at least i will mod them with self-made cable and velour pad...
Nov 18, 2008 at 11:31 PM Post #21 of 25
Originally Posted by Andrew_WOT /img/forum/go_quote.gif
That wasn't a question what is better or not, OP asked for something similar to K271S and K702/701 is not. And, btw, if you consider K702 having more bass than K271S you definitely have fit issues and should try switching to velour pads, they increase both comfort and sonic aspect of K271S.
I don't agree with this - I've had my k271 for a while now and even with velours they have less overall bass than the k701 with the possible exception of very low bass. (the natural closed headphone advantage).
Neither is a bass-heavy headphone, though.
Dec 22, 2008 at 6:19 AM Post #24 of 25
slips into the room...grabs a corner table and puts on "Maxine" from The NightFly...you know the 240S with the velour pads...is already tres especial...wondering what the diva cables will invoke...stubs out cigarette and leaves the room....
