mono
- Jan 10, 2005
Yes the ground channel opamp uses current.
If you are concerned about current you might need to rethink your topology (as-is already), since 130mA is already very high. What would cause that? Two single channel opamps for L & R plus 4 stacked BUF634 in wide bandwidth mode?
A three channel amp (opamp in L, R, & Gnd) can use about 24mA, maybe 5mA more for misc. things like a TLE2426 and an LED. Put a BUF634 in L & R channel and you're up to almost 60mA (depending on how wide the bandwidth is set). 130mA is usually overkill though, even for class A.
Originally Posted by vixr So thedoctor, when a unbuffered ground channel is used in a buffered left/right design it actually uses more current? I understand how the 2426 could be used to create Vgnd and the 134/buf would create the Ognd, but this wouldn't raise the overall current draw even higher than what I have now? (appx. 130 mA) |
