mvw2
- Feb 9, 2007
True. I should clarify "ear flat." It's something I'm very familiar with, but I am tossing the word "flat" out there generically. "Ear flat" is what I want, what I'd like to shoot for. Yuin seems to do this very well. Something I've become accustomed to is to run a pink noise track and EQ hardware (ear) flat with that. Some companies fair very well knowing what someone perceives as flat. Yuin seems to be one. I can't add or subtract more then 1dB anywhere before messing up the response. Most other HUs as well as many other hardware (home or car) requires a good bit of EQing to flatten out. I'd like to find a set that starts out close to flat so I don't have to do this.
Transparency is the ability for the driver to not bring attention to itself. It takes a certain level of fidelity to pull off, as well as a lack of distortion, mechanical noise, or vibration of the structure. It's not hypnosis, it's good design. I'll agree it's very hard to do, completely, but it's not impossible. I've only run a very small handful of hardware capable of this, and each was a front runner product in its category, almost elitist, not necessarily expensive though
, just done right.
I don't worry about hypnosis because our mind is already trained to recognize the spacial cues and represent them. It just takes an earphone to make use of this and mimic the sound stage. We already do all our own internal trickery.
Why worry about some preconceived notions of what they should sound, be, or test like?
Because it should sound "right" to me. Why would I be buying them if they don't? Isn't that the whole goal here? I don't know about you, but I'd like to find a earphone that sounded "real" to me. I already have my preconceived notions of what is "correct," "real," and "right."
The down side is to find that "right" earphone requires me to listen to about 100 different products and actually see which one sounds "right."
Back on searching, plowing through reviews/comments, I came across Head-Direct earphones. There seems to be a number of positive reviews and comments on them. As well, the prices aren't all that bad. I'm kind of curious about the RE0.
