Yeah, but i wanna use the RCA to connect the dac to my Bottlehead Crack amp + HD650, so i need another output to feed my speakers.. atm im using a Xonar Essence in the same way, RCA to Bottlehead and the headphone output to the amp/speakers - i can select the out i'm using from software
Gotcha. You also need to confirm whether both line out and headphone out work at the same time. Unless somebody else can chime in, I'll take my micro iDSD to work tomorrow (where my iDAC2 is) and check that out for you.
Wasn't sure what you were hoping for WRT output impedance of a preamp (which is essentially how you'd be using it), but I guess lower is better. At least that's what I found here:
http://www.audiokarma.org/forums/showpost.php?p=23262&postcount=5
