I haven't had that issue either as yet although I changed launcher straight away and uninstalled that big list of apps via adb I posted. I have 'use GPU for 2d' on in Developer options also. I pretty much solely use Neutron, sometimes Hiby, Mango player is uninstalled. Maybe its related to something above. I also never had the issue on dx150, dx200 or dx220 but none of those where left stock and didn't use Mango player on any of them either other than to confirm I didn't like it still
iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
- Thread starter Paul - iBasso
p.s. which headphones are you guys using that have had the issue and is it 4.4/3.5/both
mungster
To bad they don't have a software diagnostic tool to run to see if all hardware is performing up to spec.
DaYooper
I haven't had an issue at all but I am using Focal Clear Pro almost exclusively. Sort of burned them in together, ~300 hrs now. 4.4
jamato8
I have used everything from the Focals to the Abyss not really any issues, just one time I did a hard restart. Not anything I care about. Even my Supra started weird the other day, and it costs a fair bit more than the Max. Running the SR2 right now, really a good combination.
- Oct 14, 2013
You have SR2 already ? Woaaaa, more informations pleaseI have used everything from the Focals to the Abyss not really any issues, just one time I did a hard restart. Not anything I care about. Even my Supra started weird the other day, and it costs a fair bit more than the Max. Running the SR2 right now, really a good combination.
DaYooper
I loaded Roon Remote on the Android side to see if I could, it did. But..I was playing some tunes and didn't really care for the sound. I'm not sure which "player" the device is using when using the Roon Remote but I went BACK to Mango OS for the sweeter sound.
jamato8
I wish. I know they are coming out and can't wait! Sorry, it was a typo, SR1.You have SR2 already ? Woaaaa, more informations please
Yeah not a Mango fan unfortunately, Player or OS sound wise for me. A shame as I like the idea of Mango OS,
- Feb 10, 2006
Heir 8A ciem and modded Fostex T50RP, 4.4.p.s. which headphones are you guys using that have had the issue and is it 4.4/3.5/both
normie610
Perhaps I missed this info, but can anyone please describe Max’s battery life? Thanks in advance.
Mine popped up when I'm only using SE. The balanced connection seems fine for nowp.s. which headphones are you guys using that have had the issue and is it 4.4/3.5/both
Automata
- Apr 7, 2017
Has anyone try the apple remote control? Does it compatible with the max?
- Oct 14, 2013
It depends on what you hook it Into, also the loudness as well and also seems that MangoOS doesn’t have a correct battery display on Amp and DAC. But it is safe to say that I have seen it stabilized around 8 hours or soPerhaps I missed this info, but can anyone please describe Max’s battery life? Thanks in advance.
I get about 6-7ish, 7-ish, & 8 for Hi, Med, Low gain settings on the amp side and 7-8 hrs for the DAC side. All while playing Spotify.Perhaps I missed this info, but can anyone please describe Max’s battery life? Thanks in advance.
edit: because I forgot what I was writing about
