- May 7, 2017
So silent here.
I know. It is dragging too long. My savings would go to another direction.
So silent here.
rumored price is $2000? it will need to beat A&K Kann Cube.
And then there's also something else from another manufacturer with dual AK4499EQ (after SP2000 as well as M15 / M15 Pro)彩色版的DX160,以及之前已经亮相的DX220MAX,预计都会在10月份上市。
On and on it keeps going. Best learn when to stop.Seemed to be coming in October then?
https://m.weibo.cn/detail/4413866173633503And then there's also something else from another manufacturer with dual AK4499EQ (after SP2000 as well as M15 / M15 Pro)
https://m.weibo.cn/detail/4414008456869567
12,000 to 13,000 RMB so that's gotta be under 2,000 bucks, expecting a launch event to be held by the end of 2019. The height should be 7 cm while they claimed that's slightly smaller than A5 paper size (14.8 × 21.0 cm) and supposedly that might be somewhat similar to an iPad Mini?音律美
这边没拍照,和他们聊了聊,从一个朋友那听到这家也在做移动台机,问了下具体情况:型号暂定为W1(Windows1?),价格1w出头,应该一万二三的样子,看了下工程机的图,大约A5纸再小一点点,厚度大概七厘米左右的样子?声音已经基本调好,满血8通道版双4499,标配两块可以单独充电的1w9的笔记本电池,使用正版专业win系统,音频算法本身会比安卓更好,触摸屏,目前看应该是类似初代iPad的面板,黑边比较宽,但是厂家说正式版的黑边应该会控制到目前iPad Pro这样,我觉得就合适了,再窄其实就不方便操作了。SD卡槽有三个,1高速2普通卡槽,每个支持到512G,两个USB口可以接移动硬盘。年底应该会在广州搞一个发布会,期待一下
Get an n8 and a person can stop!On and on it keeps going. Best learn when to stop.
