iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
- Thread starter Paul - iBasso
strange... dx150 connected to 5GHz net, was working few hours, lost connection and as usual can't see 5GHz net.
setting of router and dx150 wasn't changed.
Lurker0
To troubleshoot WiFi issues on Android devices, I'd recommend to use Wifi Analyzer.
yes, I did.
when dx150 can't see 5GHz net WiFi Analyzer can't see any 5GHz net neither.
maybe I will try Your soft for dx150. are there any WiFi optimizations?
Lurker0
No.are there any WiFi optimizations?
You may try to figure out with Analyzer which channels DX150 supports, and check it against your router settings. If your router is configured for auto-select, it might jump to unsupported channel.when dx150 can't see 5GHz net WiFi Analyzer can't see any 5GHz net neither
It might happen that WiFi antenna went out of the main board connector inside. But it can be checked with the signal level at 2.4GHz: if the signal stays at reasonable level, then the antenna should be fine.
i think the problem is 5ghz from router. my 5ghz band works better near to the routeryes, I did.
No.
signal is strong. I will test channels, try manual settings. Thank You.
Has anyone noticed really laggy entry when searching for artists in Tidal with the DX150? I'm using Lurker's firmware v 2.10.275-L1.
I rebooted my DX150 after having it on with no reboot for a week thinking that might help - no luck. Also curious, is this lag exclusively a DX150 thing or is the DX200 comparably impacted?
Sniperpr5
- May 4, 2017
I don't experience much lag using Tidal on Lurker's fw. I mean the dap isn't as snappy as my iPhone X, but I wouldn't really expect it to be.
stupid question. i have a quick charger of my lg v30(9v and 5v). it´s compatible to charge dx150?
Yes.
- Aug 10, 2010
Did a rather long review of the DX150, there is much to talk about and it is not a cut-price 50% performer of the DX200! Really rather good!
https://headfonics.com/2018/07/dx150/
wmacky
- Dec 24, 2009
Can the DX150 make a USB connection to an external DAC?
Yes, can
Doctortre2481
Any amp 7&8 reviews /comparisons?
