maibuN
- Aug 11, 2013
does Wimp-hifi work on the dx100?
I didn't format the 128gb, just dropped music on it and it worked fine.
I have a 128 on the way, hope it just works
They do work. I received mine today (it was stuck in post office limbo for a couple of days). I am loading all my music to it right now, which is taking quite a while as I am loading over 100gb of music.
As a quick tip as hinted above, put the card in then go to storage and erase all SD data. This will format your card so your dx100 can read it.
don't you love the "sticky" post office! Mine's due for delivery today but it'll probably be the weekend before I can start loading, I have two full 64s I want to merge.
Thanks for the format hint
Generally USPS is pretty fast around here, but the past week or so its been kinda slow. For a while there it did not matter what type of option I chose I got in 2-3 days even from far away states. Now everything has been taking a week or so.
Anyways I found out the hard way that transferring 100gb of music from 2 sources at one time. It ended up freezing at around 70gb of music. Also as a quick tip (I do not know why I did not think about the transferring source before attempting this) the fastest way to write data on my computer was to hook up my DX100 through usb. Then I used the SD card slot on my computer with the 128gb card in it to transfer from the internal DX100 memory to the card. Transferring files was about twice as fast compared to having the card in my DX100 and transferring from internal memory to the dx100 SD. It worked the same way for transferring 64gb card to 128gb card ( I only have 1 SD slot).
I'm going to do mine one card at a time overnight, I've copied everything to PC and I'm just waiting for the card so I can start...
