squelchy451
- Jun 28, 2011
Hi. I usually listen to orchestral music on my ATH-AD900 and whenver the lower instruments play, e.g. cello, trombone, etc, there is a bit of a buzzing noise. It sounds like very grainy static.
My configuration right now is playing flac on VLC through Sound Blaster X-fi Go USB sound card.
Now, my old Sennheiser HD428 doesn't have the same problem.
Also, when I use onboard audio on my desktop (and also my laptop) this problem solves itself, but the sound quality overall is better on the Sound blaster, so I want to solve this problem.
I tried removing some hair from the drivers, and it doesn't solve the problem.
What should I do?
Thank you
What should I do?
Thank you
