phunkfarm
- Jan 11, 2012
Q40 has the threaded 3.5mm or I'm ok with a micro end to snugly fit inside the Q40 if we can't match the thread with a high quality fitting. The other end needs to simply fit an E11. Want a high quality braided mesh cable good enough to straddle the diminishing dollar, bang of buck value that you'd recommend! The cable will be in my pocket for the most part so I don't need or want a lot of flex. I'd prefer to opt for a bigger gauge. Please provide recommendations, both builders and pre-mades as I don't solder. Pete
