hifidk
- Feb 19, 2009
My main headphones at the moment are W5000, AD2000, HD580 Jubilee, D2000 and HF2 (ordered). Might want to upgrade D2000 to D7000 later on but it is not going to happen anytime soon. So I have low to mid to high impedance headphones and I am not sure if there is some other amp that does well with low to relatively high impedance phones.
I currently don't have much complains regarding the Cantate.2 but was wondering if there is any better option for me. I just thought suggestions from more experienced head-fiers might help me get the best out of my headphones. I don't mind getting tubes or separate DAC unit but my main concern would be the budget. I don't want to use much more than what I will be getting back from selling the Cantate.2 I guess I can put additional ~$100 or $200, which would be around $500-600 total.
So, is there anything you feel that I am missing out? Is there any better option? Would it be better to save up more and get higher-end gears?
Any input would help.
By the way, if it matters, I listen to most music genres except classical music. I mainly listen to Rock, Electronica and little bit of Pop/Jazz/Vocal stuff.
