U-3C
- Oct 12, 2015
A bit of an update: I just found an album which I never re-ripped to FLAC, Trading Snakeoil for Wolftickets by Gary Jules. I would have ripped that to 128 kbps MP3 using iTunes around 2006. I was noticing some REALLY bad intermodulation distortion, so I re-ripped the CD to FLAC and here are my results from an ABX:
08:16:29 : Test started.
08:16:47 : 00/01
08:16:58 : 01/02
08:17:10 : 02/03
08:17:19 : 03/04
08:17:29 : 04/05
08:17:48 : 05/06
08:18:08 : 06/07
08:18:16 : 07/08
08:18:26 : 08/09
08:18:38 : 09/10
08:18:45 : 10/11
08:18:53 : 11/12
08:19:00 : 12/13
08:19:08 : 13/14
08:19:16 : 14/15
08:19:26 : 15/16
08:19:26 : Test finished.
Total: 15/16
Probability that you were guessing: 0.0%
I'm pretty sure that first mistake was just me hitting the wrong button. I did this to gain back a little face and demonstrate that I really did hear a difference between 128 kbps MP3s and FLAC, but that this was a result of iTunes using a lousy encoder and not a limitation of MP3 itself.
Yeah, I also have some songs that were ripped terribly from many years ago. I didn't care back then, but now, I can hear a clear difference.
To be honest, I still don't care. 128 kbps isn't "unbearable" like some people love to claim. I do tend to notice the lower quality more when using higher end headphones. Whether or not that is placebo is unknown, but it does degrade the experience a slight bit. I personally find that they lack that extra "oomph," but not enough to make me take a few minutes to re-rip them.
How much do you personally think it matters, the loss of quality from flac lossless to 128 kpbs mp3? Is it enough to affect your enjoyment or judgement on equipment? After all, one of the first questions asked when someone voices a different, negative opinion on a pair of headphones is "are you listening to flac lossless files? Make sure you listen to high quality audio or else everyone will disregard everything you say. High quality audio makes a large difference and can trick you into thinking gold is garbage."
