Thank you Steve999. It took me a long time to finally decide to take the bait on the Grados, but I'm glad I did. And, for the record, it was your recommendation of the CD780 that convinced me to try those (the $31 refurb deal helped
Since you are a big fan of the CD780, you'd probably like the SR325 as well. It is more "in your face", but IMO it shares very similar qualities. I find the CD780 brighter, in fact, using the Grado flat pads. The bowl pads make the SR325 roughly on par in brightness with the 780. The CD780 has a better soundstage though, so if a condensed sound bothers you, the SR325 may fail you there. I find however that the smaller soundstage is better for hard rock/metal, which is my main listening preference, but the CD780 does an admiral job with it anyway, the SR325 is just better.
As for comfort, which was another reason I held out for so long on Grado, was surprsing comfortable, atleast to me, anyway. Being a previous avid supporter of the true "Head-Vice Of Death", the Sennheiser HD-25, the SR325 fits firmly on my head, but feels comfortable, and so far I don't find the flat pads abrasive to my ears.
Working on a limited budget, I tried to target the most effective change, so it's my opinion as well that the headphones would make the most immediate difference. I'm happy, so atleast for now, I'm keeping the can of worms closed.
