i basso t4 output jack issue ??
Feb 27, 2009 at 5:14 PM Thread Starter Post #1 of 11
what?
the headphone 'out' on my t4 is having problems
i have to pull it out a couple mm to get a solid connection, or wiggle it about to get things right. anyone else had this?
very irritating
shall i take it apart and try and solder something?
dont want to have to ship it globally....... and wait ??
Feb 27, 2009 at 5:29 PM Post #2 of 11
edit: weird, my cheap koss hps work normally?
must be the jack on the other phones?
ill investigate further and report back
Feb 27, 2009 at 5:31 PM Post #3 of 11
edit, no its definitely the amp, im getting weird crossfeed reverb ambient mixed / mono kinda sound?
Feb 27, 2009 at 5:32 PM Post #4 of 11
that can be fixed with a wiggle of the jack?
Feb 27, 2009 at 5:57 PM Post #5 of 11
It could be a bad jack but do the Koss work correctly all the time when plugged in?
Feb 27, 2009 at 7:06 PM Post #6 of 11
My Sansa Fuze has an issue with my Klipsch Image X10s to where I have to pull it out about 1 mm of the headphone jack to to get the sound to work properly.
All my other phones work fine though and the X10s don't have that issue with any other DAP (or anything I own that has a 3.5mm headphone out for that matter such as my computer or laptop).
Feb 28, 2009 at 10:24 PM Post #7 of 11
You probably have a bad jack. If you are still under warranty I would say to ship it back and have them fix it for you.
If taking it apart and fixing it yourself doesn't mess anything up, then by all means do it. 00
Mar 2, 2009 at 2:00 AM Post #8 of 11
but wouldnt you be getting dual mono sound if you pull it out a mm??
Mar 2, 2009 at 12:00 PM Post #9 of 11
sry to hijack this tread, but for those with t4, at low volumes is the right channel louder? coz that was what i heard while testing out the amp. is this true for all t4s?
Mar 2, 2009 at 4:39 PM Post #10 of 11
my bad, it was my $3 cable
t4 is PERFECT
Mar 2, 2009 at 4:40 PM Post #11 of 11
i dont experience this?
volumes equal in both ears even at very low.
