2426
- Apr 6, 2006
Actually, for $20 more than your original budget, you could get the SR225. They are $200 and should be a big step up from the SR60.
Originally Posted by Boothead In reference to open and closed headphones, how much sound is leaked out in open ones? Is it truly bad in that peolpe around you can hear the music almost half as loud as you are? |
Originally Posted by 2426 Actually, for $20 more than your original budget, you could get the SR225. They are $200 and should be a big step up from the SR60. |
Originally Posted by warrior05 okay, we need to try and reel in the description "INSANE amounts of bass" a bit. let's try a comparison - DT770/80. the DR150s are not as in your face with bass as the Beyers. also, they - the Goldrings - are not boomy. the bass is tight and well represented and, yes, they are somewhat elevated but do they not drown out the mids or the highs at all. the Beyers have such recessed mids that i couldn't stand them with some music. the Goldring's are much more balanced. |
Originally Posted by Boothead I'm able to spend between $100-$180 to get my fix. |
