Voodoochile
Supafly & The Funky Pimps
- Sep 13, 2002
Potting the transformers is almost done. I'm using some thermally conductive potting epoxy from MG Chemicals; stainless bolts and pots.
Step one was to cast about 1/8" of resin in the covers:
Attached leads and fiberglass sleeving to transformers:
Set leaded trafo on cured 1/8" epoxy "floor", to keep the
trafo away from the pot. Plenty of room:
Disc to hold studs and leads in position for curing:
The pot is about 3/4 full right now. When it's cured, the nuts and disc
will be removed, and the pot will be topped off to within 1/16th of an
inch of the rim, leaving just enough clearance for a 3/32" silicone pad.
The holes in the disc are an exact match to the top plate of the amplifier.
Details on the top plate will be in a seperate thread.
