regal
- May 27, 2006
[size=10pt] I made a sketch of the prefiltering power supply chassis, I had the two transformers so made it a completely split supply at the time I started it was thought that the Salas reg would be best to have a separate reg for each channel, way overkill and time consuming. This way I have flexibility to try some output tubes like 45's or the PX4's with this, inside the amp chassis at each regulator there is an additional RC (3k &5 uf can) right at the regulators as I had to drop the voltage a lot before the regs. Hammond seems to have a lack of high current but lower voltage power transformers. Ideally one wouldn't want to use such a large resistor in the prefilter but it simulates to around 1mV input ripple. Cool thing about the Reg is even with this heavy filtering the final B+ output impedance will be well under 1 ohm.[/size]
[size=10pt][/size]
[size=10pt][/size]
