Sweetmeat
- Aug 29, 2008
If you've never looked for it, you may not know it's nearly impossible to find a data cable with an RCA plug on one end and a mini phono plug on the other end. I was shopping for that exact cable for the headphone system I use at work. The cable would go from the digital output of my iBasso DX90 player to the digital input of my Burson Conductor SL 9018.
In the meantime I was using the adapter supplied with the DX90 along with a standard audio patch cord. I needed to use a 1-foot patch cord because if I used anything longer than that, there was no sound at all. Even with the shorter patch cord, I was getting a lot of dropouts. After a little research I determined the dropouts coincided with operation of one of the many electrical devices in my office, which I share with several other engineers.
So I set out to find a shielded SPDIF cable, with the connectors I needed, that will operate at standard lengths. Eventually I found that WyWires builds custom cables, and I made contact with Alex Sventitsky who is Presedent & CEO. He was an extremely gracious fellow, and personally took my order for a 4-ft "Blue" SPDIF cable. I received the cable two weeks later.
The cable is extremely well-built. The RCA jack is an adjustable Furutech and the mini phone plug is the sturdiest I have ever seen. The cable cover is very rugged although the cable is not as flexible as I would like. It turns out that Alex uses thick copper shielding for these applications, so his cables are stiffer than others. I can live with it.
I took the cable to work and plugged it in, and I was relieved that my Sabre DAC would operate with the 4-ft cable. Unfortunately the dropouts continued. I tried everything it seemed like - a Cardas filtered power cable, Furman power conditioner, aluminum foil wrap - nothing worked. I tested the AC plug for polarity and ground, and it was OK. Throughout these tests, I remained in contact with Alex who offered concern and helpful suggestions.
Either Alex feels a great responsibility to provide customer satisfaction or he got tired of my emails, but he offered to re-build my "Blue" cable with the same wire used in his newest USB cable. He said the old USB had troubles with sync when the length exceeded 7 feet or so, some of the new USB are 10-12 foot with no issues at all. So I accepted his generous offer to re-build.
I've been using the rebuilt cable for a week now with no dropouts. Well, it did have one short dropout but that could have been an under clock event between the DX90 and the Sabre. However the new cable is not completely impervious to RF, it will still drop out when I turn my own desk light off, but I don't do that while I'm on the cans. Overall I am very, very satisfied, and plan on using WyWires again in the future.
