Zerox Millienium
- Jul 18, 2008
Hello guys please anyone here knows how to test the power handling of a full size headphones?
I think it could be an issue for example if you try to eq up the lower bass of a bass light headphone.My personal opinion is that you don’t need such a value for headphones(as a consumer!). Because headphones are always going to reach dangerous levels for your ears before it gets dangerous for the drivers. So just care about preserving your ears and it should be enough to also avoid melting a coil or blowing up a membrane on your headphone.
I’ve killed a cheap earbud(lucky!) doing step response measurements in REW. The settings aallowed for pauses between frequencies, but wanting to measure several IEMs and be done fast, I didn’t redo the level calibration(stupid) and removed the pauses that let the coil cool down(well done Einstein). With the result I deserved.I think it could be an issue for example if you try to eq up the lower bass of a bass light headphone.
(In fact I think I damaged my AKG 240 that way when I was very young and very stupid, lifting the 16(!) and 32 hz sliders of my graphic eq to +12 dB. It didn't melt down but it now resonates at certain bass frequencies.)
