How to test for bit perfection?
May 22, 2006 at 1:34 AM Post #16 of 19
Originally Posted by sgrossklass
That shouldn't be. I still have 0.8.3 here, but using no DSPs at all is no problem.
As for whether you need an amp, if you external DAC (model?) has a headphone out of decent quality you may be able to do without. The 7/8 out on the AV-710 basically is not suited for cans.
no brand!?! seodu SDC -1000 on the back no idea how good it is
May 22, 2006 at 12:57 PM Post #17 of 19
May 22, 2006 at 1:14 PM Post #18 of 19
HDA SDC-1000 20bit/48kHz Dolby Digital DECODER/MADE IN KOREA
Decoder DSP
CS49305 Dolby Digital/Dolby Prologic decoders DSP (Cirrus Logic)
CODEC (ADC/DAC)
CS 4226 20bit/48kHz CODEC (20bit/48kHz 2CH ADC/6CH DAC)
DOLBY DIGITAL
Dolby Digital 5.1/Dolby Pro Logic/Dolby Stereo
Digital/analog input
Digital Optical 1 (TOSLINK)
Digital Coaxial 1 (RCA terminals)
Analog Line Input 1 (4 Channel input)
- Front L/R: [phu] [lon] [thu] analog input 3.5mm mini jacks
- Rear L/R: Rear analog input 3.5mm mini jacks
Line out output
4 3.5mm mini jacks ([phu] [lon] [thu] and rear, center and right to ladle)
From DSP round mode support
(Crystal Original Surround)
Bypass/Stereo/DSP Surround Music/DSP Surround Theater/DSP Surround Stadium.
Sound Function control
Center Delay/Surround Delay (Dolby Digital 5.1)
Dynamic Range Compression (Dolby Digital 5.1)
[li] wool [thu] control
Power On/Off, each Channel star volume controls, Input selections, Surround mode selections and Function selections, Mute Control and Test Tone
Power On/Off Switch
Standby-mode power switch
LED indications
Program (5.1 ch compressed audio stream) where it leads 7 Segment LED format/various settings display
Additional function
2 Channel, Down Mix for 4 Channel speaker user
Digital 32kHz~48kHz spring plate support
Mastering volume level (- 70dB~+10dB)/each Channel volume level (- 10dB~+10dB)
With SMPS power failure unit circuit adoptions stable application of power/that heat generation
DC 12V inputs
12V 1A DC adapters (attention! It connects, AC when adapters absoluteness it does not become.)
May 22, 2006 at 1:19 PM Post #19 of 19
the translated version says it "does not support DTS"
http://translate.google.com/translat...lr%3D%26sa%3DG
that sad.....
