darknessproz
- May 13, 2010
As title suggested, how do i go about doing this? Are there any preferred settings?
Not using replaygain is absolutely silly.
ASIO and WASAPI are good if you have music of varying sample rates and don't want to resample. Saves a lot of cpu to let the dac take stuff in its original sample rate. Otherwise, it's fine by default, forget this nonsense voodoo.
That is, if you're using Vista or 7 - if you're using XP or prior OS then yes, definately use kernal streaming or ASIO.
wat. Replaygain has been shown to cause issues for some, do a Head-Fi search.
ASIO/WASAPI are bitperfect audio transport methods, run in exclusive mode... It's not voodoo and mumbojumbo. Also, I still resample everything to 24/88.2 and use WASAPI, so I'm starting to think you haven't really tried these things.
I never said replaygain is bit perfect, it's the same as using any digital volume control. Better to use a bit of sw volume control to help cancel out some of the problems created by loudness war failure. No point constantly fidgeting with the volume control or accidentally blasting your ears.
As for wasapi, asio, resampling:
Resampling does seem to soften the sound, but it's not a big enough difference to care. It still has the same sound, but ceases being bit perfect.
KS and ASIO made audible differences with poor quality mp3 files back when I used XP and earlier, I see absolutely no difference in Vista/7 which use a much better audio stack, therefore it's placebo effect.
I'd appreciate if you stop following me like a lost puppy![]()
I'm gonna go with WASAPI, as it turns off all other sounds.![]()
If you have real ASIO drivers anyways.... ASIO4ALL rapes cpu usage
Originally Posted by Dalamar /img/forum/go_quote.gif
No idea
Yes, we got that from reading your enlightening posts indeed![]()
DS cannot be made bit-perfect on Vista/W7: http://www.hydrogenaudio.org/forums/index.php?showtopic=49350&st=200&p=522247&#entry522247
and A4A is indeed a KS wrapper, and that's perfectly fine as the main goal of ASIO is to bypass KMixer in a low latency fashion...nothing more.
I'd suggest the OP to do the complete opposite of what that guy says, just to be on the safe side![]()
