How to safely drive headphones with a speaker amp?
Jun 29, 2015 at 11:13 PM Post #16 of 27
Anyway...the STAX system I got today is easily the best, most realistic headphone system I have ever heard -- and it's only an entry-level model from the 1980s! Can't wait to upgrade to high-end STAX. Thanks everyone for all your advice. Like I mentioned earlier, I suppose by the time I get more headphones that need an amp, I'll be able to afford the next amp/DAC I wanted. Maybe someday I'll try out this DIY stuff with speaker amps and headphones, just for fun.
Jul 1, 2015 at 6:57 AM Post #17 of 27
Googled and found these links:
"Spade plug"
http://www.amazon.com/Sewell-Premium-Degree-Connector-Pieces/dp/B0050CEA40
http://www.speakerrepair.com/ebaypics/new-spade-plate-500.jpg
"Banana plug"
http://www.nakamichiplug.com/product-2503.html
https://www.youtube.com/watch?v=ybRqeCkgXWs
And from my post above:
"Male 4-pin XLR plug"
http://www.amazon.com/Neutrik-NC4MX-Connector-Nickel-4-Pin/dp/B002EDO2K0
"Female 4-pin XLR plug"
http://www.bhphotovideo.com/c/product/748113-REG/Neutrik_NC4FX_B_NC4FX_B_4_Pin_XLR_Female.html
over 90% of amps have common output ground. Unless a balance connection is needed, cheap and chearfull gets it done. Check amazon.
If we want this to genuinely be good and drive reactive loads with a low impedance source, buy a headphone amp.
 If you don't have a line/pre out, you can even run a headphone amp off the speaker outputs with series resistors as well.
Jul 1, 2015 at 7:01 AM Post #18 of 27
You may want to consider a better model fro the era. The later ones get very open sounding but a bit ethereal. The lower bias units with some rear padding are less open but more solid. Original Lambdas are pretty cool. I also got a great result by opening up the front of some SR5s a bit more and removing about 1/2 the rear damping.
Jul 1, 2015 at 11:25 AM Post #19 of 27
Oh, I'm upgrading to the SR-009 as soon as I can afford to.
Jul 1, 2015 at 5:10 PM Post #25 of 27
  They introduce new models faster than your wallet can handle them. Buahaha, you will never catch up.
Think about it. If I'm able to collect all the existing headphones in the world, surely I would be able to collect the new ones too.
(But really, I only want to keep a handful of headphones, after I've discovered which ones are ideal for me.)
Jul 1, 2015 at 5:13 PM Post #26 of 27
I hope you have a warehouse.
