sjlukacs
- May 12, 2010
hello one and all,
i know that i can record holophonic audio using the foam head and binaural microphones, then pass it through hrtf.
however i am looking to do a more simple thing. i would like to place a narrator in front of the listener and say soft ocean, wind, or forest sound behind the listener. i should be able to author such placement of mono or stereo recordings in a 5.1 software like apple soundtrack pro or adobe soundbooth and then create a multichannel audio file, like wav or so.
where i am stuck, is, is there a way to take that exported 6-channel audio file and use some utility to compress it down into an mp3 file that will preserve the 3D spatial holophonic effect when the user hears it in nice stereo headphones, like the barber shop or matches demonstrations that are all over the web.
so, i know that mp3 can store the holophonic effect, i just want to know how that mp3 file is created. and really i just want to do a simpler thing then recording in full 3D.
thank you in advance and have a great day. lucas
