ShibeSuchBass
- Dec 14, 2013
I have JVC HA-FX1X earphones, which are pretty great for me, excellent bass, not muffled and dark sounding like a lot of other bass orientated headphones. Their normal sound isolation is good, but i need better. When i listen to soft audio, like ASMR or put my music on low volume, i can hear almost everything around me like a fan, in the room, people walking around, and if someone is talking in the house, i can hear them perfectly and it ruins everything. I found out you can put on your earbuds and then put on some ear protectors like this, so that is a cheap option, and i need cheap. Although, i think they may look too bulky and big. So what are ways you think, or do, sound isolate in-ear headphones? Replace the rubber tips? I hear foam tips are better, but idk how to find the right size, unless theyre the same size around the little hole where they are held in place? Some other kind of contraption or DIY thing? Anything, please.
Also, what would be the best, low priced (+/-$50) IEM for excellent sound isolation and bass performance, im a basshead
Im also open to recommendations for full sized headphones, but i would rather buy IEM earphones probably.
Any help? Please and thanks!
