ComfyCan
- Feb 16, 2006
I just picked up a used VPI 16.5 RCM off e-bay and I'm enjoying the benefits of clean records. I am, however, wondering where the waste fluids are going. This unit was originally a HW-16 that was upgraded by the previous owner to a 16.5 (not sure if that matters or not).
The instruction manual available on the VPI site refers to some kind of hose assembly to use in draining used fluid, but my unit has no visible hose and no port on which to attach one. I assume the fluid is just accumulating in the reservoir below the vacuum pickup tube assembly. Is it possible to pump the waste fluid out through the port where the vacuum pickup tube assembly goes? Or, is this a "non-problem" that I should stop worrying about?
Thanks. Oh, and by the way: this thing sounds like a jet aircraft on takeoff.
