renlute
- Oct 31, 2009
I had AKG-Harman replace my K240DF cable last fall, but today the bleeping thing is loose at the connection point to the can. The technical problem is that I get no left channel sound unless I pull up on the cable where it enters the little housing.
I will contact their parts/repair department tomorrow morning but am afraid they will tell me that any guarantee is expired. That was a $70 repair job, so needless to say I am very displeased with their workmanship.
How hard an operation is it to get in there and fix whatever wire is loose? I don't even know how to get the lid off. It must not be easy, the repair guy gouged the rim a couple times and it does not fit tight now as it does on the other can. I found an exploded diagram but it appears to depict the 240M model, not the nondetachable K240DF.
http://www.akg.com/mediendatenbank2/psfile/datei/36/K240_m_stu4055d215ac91a.pdf
