barleyguy
- Apr 28, 2009
I only temporarily connected them analog in order to discern which ports had the hum on them (because the ProFire doesn't have any hum). Normally I run the ProFire 2626 with two Tangos connected via optical.
Computer->Firewire->ProFire 2626->Tango In and Out Optical
when measuring, it was either:
Tango Out->ProFire In or ProFire Out->Tango In. (I also tried Tango loopback, but looks just like the output.)
The power input section is a combination of Voltage Regulators and Electrolytic capacitors. I'm pondering whether I should re-cap them and see if it helps. I'll try to post a picture soon (been working too much).
Thanks,
Harley.
I'm starting to get confused about your set up, you say you're connecting the profire and tango through an optical cable, so how are you measuring the analog outputs of the tango? Are you looping them into it's own inputs? Can I see a picture of your setup?
Thanks,
Harley.
