how to connect a head phone cable to a 3.5 jack
Jul 7, 2007 at 3:07 PM Post #3 of 3
If you can cut off the molded rubber/plastic around the OEM plug you can find out which colored wire went to which solder point. Typically, red = right which is the ring part of the plug. Bare wires are typically ground. But it would be best to be sure.
