How to chenge Ipod internal battery?
Apr 4, 2006 at 6:06 PM Thread Starter Post #1 of 6
NEO
Hi,
I ordered battery for my 30GB (3rd Gen) Ipod but not sure how to change it. I remembered seeing the procedure with pictures somewhere on the web but not sure where. Does anyone know the link or website that provide the procedures with pictures?
Thanks,
NEO
Also, how should I keep the battery if I am not changing it immediately?
Apr 4, 2006 at 6:30 PM Post #3 of 6
Did you try searching ilounge.com ?
Apr 4, 2006 at 9:16 PM Post #5 of 6
Thanks guy, that helps a lot.
Does anyone know how should I keep the battery if I won't change it at once? I was told that putting it in a fridge can damage the cell.
Apr 5, 2006 at 7:43 AM Post #6 of 6
Originally Posted by battery university
# Avoid purchasing spare lithium-ion batteries for later use. Observe manufacturing dates. Do not buy old stock, even if sold at clearance prices.
# If you have a spare lithium-ion battery, use one to the fullest and keep the other cool by placing it in the refrigerator. Do not freeze the battery. For best results, store the battery at 40% state-of-charge.
http://www.batteryuniversity.com/parttwo-34.htm
