waddragon
Banned
- Jan 7, 2008
I have just bought a used DAC1 USB from Jimp. However because he didn't have enough time to change its voltage into 120V , I have to do it by myself.
any helper will be appreciate
right now when I open the drawer which is near to the IEC. I see two fuses inside it . I also have two extra fuse.
However all four of them are 500mAL250V(the same).
I read the instruction and know that 110V setting is 0.5amp , 220V setting is 0.25V
from each fuse, there are two sides (one has the letters 500mAL250V, and the other only has strange symbols).
From what I think I need to put 500mAL250V side up for both fuse. Is it correct?
how can I change the switch into 110V? I don't see any switch in the drawer?
Opp, I see the switch now . I just need to take the white drawer out.
plz help me, pictures will help me a lot
I posted some pictures to show you some of my option(SYMBOL option and 250V option) for the setting. plz show me which one will be correct.
I also have 2 JUMPERS . What are they used for
here is my pictures:
Flickr: waddragon's Photostream
thanks
thanks
