thomaspf
- Aug 30, 2003
@Don Quichotte
That's quite possible. That is actually how an asynchronous sample rate converter works.
You have two separate clock domains. The inherent clock in the incoming digital signal and and independent local clock. The sample rate converter is clocked by the local clock domain and just receives whatever samples the externally clocked digital link will provide. At the end of a unit interval it will translate this potentially arbitrary number of samples into to a fixed set of samples with "different" values and hand those to the converter.
Even if there is zero jitter in the input but a certain drift in the frequency then the likely outcome is that all samples are different.
In order to avoid this problem many professional sound cards come with a word clock input that allows you to slave the digital output to the external clock in the DAC.
Cheers
Thomas
Cheers
Thomas
