beeman458
- Jul 4, 2010
If you're counting only the Xonar STX sound card and the upgraded power supply, less that $400.00 USD. But I have to write, getting a top dog headphone like a HD-650 is a big plus.
setekh wrote:
Dalamar makes perfect sense.....
Don't be writing that, he'll become incorrigible. Oh, wait.....
j/k
EDIT: beeman458, I'm not sure how your post fits with the rest. Is there something I'm missing?
In your OP, you wrote below:
Anyway, I was wondering what kind of system would be deemed acceptable by your standards. I mean, how low-end can you get without taking a huge hit in quality. I don't consider myself to be
My response was in response to your above. I tried to put some context in my response below.
In the case of a new desktop, you want at minimum, a top flight sound card like the ASUS Exxence, Xonar, STX instead of the onboard the MoBo sound processor. And it doesn't hurt, when putting your desktop system together, to have a top end power supply added because the Xonar card needs it's own 12v molex power supply. In the end, you want to buy the best set of headphones you can afford as I don't think too many people would argue this point.
Sorry for the loss of context. I was veerrry late to the party and wasn't watching the OP date.
The M-Audio and Berhinger ranges sound o.k. but they don't last very long.
Fostex make the components other manufacturers use so their own brand is good value. So are Samson.
If you can afford a bit more.
KRK Rokit range is good fro pop and electronic. ADAM are good for acoustic and classical. They'll both do rock well.
Mackie are also popular.
After that also consider Dynaudio, Focal or money no object Genelec & Event,
I get the impression what most audio pros fart about on at home are either Genelecs or ADAMs. ADAMs are less expensive and have a 5 year guarantee.
It's all about power and weight. What happens in the lowest 2 Octaves.
Samson Resolv 5a have a 5" driver which claims to go down flat (+/-3dB) to 50Hz and offers 140W pair.
Samson Resolv 6a have a 6" driver which claims to go down flat (+/-3dB) to 40Hz and offers 200W pair.
Fostex PM0.4 : 4" : 60Hz : 80W.
Fostex PM0.5 : 5" : 50Hz : 140W.
To give you some idea human hearing is generally regarded as extending from 20Hz > 20kHz and a full range audio system will cover it all. Although many authorities don't think it's worth the trouble to go much below 40Hz in an ordinary domestic setting (or get a sub and acoustic treatment).
For comparison the popular M-Audio AV40 don't bother going below 85Hz. My desktops go down to 60Hz and I rarely feel the need for the sub or big floorstanders unless there are loads of people round or I'm in a mad up for it mood with some new tunes.
Ideally you need to listen to different sized drivers and decide for yourself 'how low you want to go'. Or how low your neighbours can tolerate.
As a suggestion. If you want something for your desktop only then the Fostex PM0.4 will be fine (and comes in cool colours this year). If you want to try to a fill a bigger space, must have loads (too much) bass or enjoy regular loud sessions then the Resolv 6a look a better bet.
You will not get a full on dance party going without at least an 8" driver which is outside your budget but you can always save up for a sub later.
Mmmh. Dunno. I'll share my experience in case it helps you decide.
I have a large room 5mx7mx4m. Classic floor standing speakers. 32Hz : 240W. Perfect? 20 years ago maybe.
So I bought a pair of M-Audio AV40. 85Hz : 40W. Brilliant when I was sitting at my desk. Still needed the floorstanders though.
They broke down pretty quick unfortunately but I was so delighted with the concept I spent 4x as much on a replacement.
ADAM A3X 60Hz : 100W. Knocked out by the control and purity of tone. They are powerful enough to fill the room. Except? You know where the bass ought to be but you don't actually feel it. Which actually is cool with me most of the time.
I ended up with the 8" sub as well but actually it's a monstrous extravagance because it's the most expensive component in my system and I only really use it once or twice a month. Silly. But perfect again. Really flexible. Decent quality sound at 0200am. Either on my own or with a room full of people.
