Sycraft
- Jul 6, 2004
Wether idle or operational, my PPA draws 0.12 amps at 24 volts, according to my powersupply. I'm just wondering if it is supposed to draw that much, and if not what the problem could be.
I can't hear any sonic problems, the amp sounds just great, and there's almost no offset at the outputs, -1.5mv on one channel, 1mv on the other and that's fully connected to the mixer and soundcard, with both powered up (they also have slight offsets I'm sure).
The amp has 4x 5002 buffers on each channel and OP 637/627 opamps. It has all 12 Q3s filled and I made no attempt to match them. It does have the class A bias circutry, but it should be off (unless I'm confused which way to turn the varsistor).
So am I just worrying for no reason, and this is a normal draq for the amp, or is there likely a problem somewhere?
