Longfellow78
- Feb 8, 2014
Hello.
Tldr - if its loud enough is it powerful enough.
I am wondering when running Planar headphones (or any headphones) if there is a difference between "volume and power" . I mean, if I can run my Planar headphones to a deafening level without maxing out my volume control which physically hurt my ears for some time afterwards, by definition do I have "enough" power in my amp?
I ask as I am trying to decide between the fiio ka5 and fiio ka13. I have bought both and while the ka13 is clearly louder and puts out 550mw at 32ohms, and the ka5 outs out 265mw, the ka5 is more than loud enough to hurt my ears at max volume, whereas on the ka13 I can literally deafen myself.
I am running t60rp and while conventional wisdom says they need a nuclear reactor to run them (my desktop amp can do 3000mw) they sound fine on the ka5.
I am worried however that I am giving up some fidelity with the ka5, because it is so much weaker on paper, is the extra "power" from the ka13 worthwhile? I guess what I'm really asking is if you have two amps, one more powerful but you set them to the same objective volume, if they have identical components and neither is maxed out, does the same volume equal the same sound quality.
The ka13 is is way cheaper so normally it would be a no brainier, BUT the ka5 has a hardware play pause which is very important to me.
Thanks.
Thanks.
