kingpage
- Apr 26, 2010
(1ohm) -> Beyer DT880 (600ohm) = Perfect
So I had it backwards?
Ideally you want a low ohm source for high ohm headphone? and a high ohm source for a low ohm headphone?
Is that correct?
Low ohm source is almost always better. 99.9% of the time, it'll be better. The exception is when the headphone was designed to be used with 120 ohm sources, which is very rare.
Edit: Sometimes people will prefer a high impedance source, but that is very unpredictable because high impedance affects all headphones slightly differently, but generally entails a potentially less tight bass and emphasis on the 100-125hz region. I personally believe that the actual damping effect of it is lesser in headphones, as outlined in my OP post, but the effect does exist.
So if I'm understanding this correctly, using specific examples
Centrance DACmini (10ohm) -> Grado (32ohm) = bad
Centrance DACmini (1ohm) -> Grado (32ohm) = good
Centrance DACmini (10ohm) -> Beyer DT880 (600ohm) = good
Centrance DACmini (1ohm) -> Beyer DT880 (600ohm) = bad
Is this correct?
Thanks
Is that correct?
Actually, I think Grado may be one of those 0.1%, I think they were designed with the first Grado amps in mind, and I doubt these amps had a very low output impedance.
Low impedance headphones can be driven from high output impedance sources. There is nothing wrong with that.
Then why is everyone up in arms now about the measured negative effects?
Ah, well I like my Sony EX700 from a 25 ohm output impedance source, I think there is good synergy there, but I feel inclined to think that it's gin and tonic, both are sour, you mix them and it becomes sweet.
Quote:Actually, I think Grado may be one of those 0.1%, I think they were designed with the first Grado amps in mind, and I doubt these amps had a very low output impedance.
Do you mean the Melos SHA or the RA-1? Both have very low output impedance, but a fairly colored sound.
I like grados from an amp with a little (to a lot) of output impedance.
