So if i got a different cable for the HD650 instead of using the stock cable, it would improve it a good amount?
It depends. Without a good DAC/Amp I wouldn't bother unless it's a cheap DIY version.
The differences are much harder to spot. If I didn't have a PC DAC I wouldn't buy an expensive cable.
Based on my experience, cables can either:
A) Make a headphone sound worse (example is Canare on the HD-650, Belden 1192A on the HD-598)
b) Make it sound exactly the same mostly
c) Improve it (maybe it's that magical dust, but it's stupid easy to spot the improvements with some wire)
I've noticed that with the cheaper stuff found at places like Radioshack, Wal-Mart and Uncle Ernies, the sound is often fairly neutral.
I actually am a fan of the crappy RCA brand interconnects because they don't seem to make anything sound different/better. Monoprice is good about this too, but they're slightly warm.
It's it's a mistake to buy a fancy cable expect a major signature change. Not going to happen. The DHC is the biggest improvement i've heard with any recable.
With CA-0363 the signature will be basically identical I think to stock. That's why I use it with my HD-598. It just improves sound clarity/detail.
Felt the DHC cable is worth around $150, but I don't think Q701 recables are that big of an improvement to be worth that. Only when going directly to the drivers.
I always felt most cables made a 3-5% improvement in sound. I still can't tell the difference between speaker cables! With interconnects it's fairly hard.
I wonder why a nice DAC makes it easier to hear the improvements between wires? I've found this very strange.
I actually couldn't tell the difference between interconnects or Q701 cables until I upgraded my DAC.
Never know why wires sound different for me. Copper is copper right? Could be to the quality of copper, thickness of the wire or capacitance.
BTW I do feel that 75% of the time, cables make very little difference. Sometimes you get lucky.
Sometimes the stock wires on some headphones are just plain bad. AKG has good cables, but I absolutely hate the stock Sennheiser cables. I haven't compared the DHC to the stock HD-650 cable ON the HD-650 yet though. Even the DHC was an upgrade from the HD-650 cable on the HD-600.
