FlatBeat
- Jun 25, 2013
Hi everyone,
I bought a set of used IEM's and one of the connectors isn't very secure. To describe it, if I dangle the Iem from the cable it dosen't fall off, but a light pull removes it with not much resistance. If it was snagged in my pocket on something it would probably pull out.
I don't have much reference as I'm fairly new to this but I had a set of penon globes that were straight up difficult to pull out, like you had to really grip and apply a fair amount of force.
These are no where near that, just a light pull and they come out with just a touch of resistance.
Is this something that would be worth looking into as a warranty?
Thanks,
Thanks,
