Shimakaze
- Aug 14, 2012
I'm looking for a pair of over-ear phones to use at work that is comfortable to wear over extended periods of time, and the HD-598 seems to fit the bill in terms of sound quality (from what I've read anyway) and affordability. The only issue that I can see is sound leakage from the open-back design. I work in a quiet office inside cubicles with 7 feet-tall walls, so they do contain some amount of sound. I don't mind being able to hear my surroundings. In fact, it's desirable to be able to hear when my coworkers need my attention, so my only concern is my music bothering people in the other cubes. Just how bad is sound leakage from open-back headphones, and the HD-598 in particular? I listen mostly to jazz and some post-rock, and never crank the volume up, if that makes any difference.
