Nocturnal310
- Apr 29, 2008
Hi guys,
this is for those who are tired of pathetic dull sound quality of their laptop and dont have a budget.
I discovered this accidentaly when a bolt of Audiophilia Wave struck me.
I have these Logitech R-21 speakers...entry level logitech speakers with a Sub-woofer.
So what did i do?
I connected my laptop to them...and used an Extension Audio cable to connect my Headphones to the Speakers headphone jack.
BECAUSE the speakers have separate power supply and a good power input...they basically Amped up my Laptops sound and gave a greater soundstage to my Headphones.
Most skeptics and Amp fanboys wont believe but i recommend u to try yourself.
You can also do it!
Just buy a set of inexpensive 2.1 Desktop speakers..preferrably Logitech as its tried & tested.... Let your Laptops out signal pass through them and it will sound much more alive via the Speakers processed headphone jack.
Cheers!
Let me know what u think of this CHEAP method of improving sound quality.
P.S: Works well with headphones upto 64 Ohm... After that u ll need a Good Headphone Amp.
So what did i do?
You can also do it!
Cheers!
