How far can EQ really go towards truly equalizing headphones?
Jun 26, 2012 at 9:18 PM Post #136 of 204
Jun 26, 2012 at 9:29 PM Post #137 of 204
guess for me that's why soundstage appears to improve significantly after tuning the headphones? (tuned to mostly electronic music like trance and house and DnB , but seemed to improve with other genres too like rock and pop) or is it something else?
I'm also inclined to believe that as less frequencies are masked, soundstage/imaging widens significantly, I have experienced it in EQing my speakers.
Jun 27, 2012 at 1:59 AM Post #138 of 204
i agree, reducing the knobs seem to increase the soundstage, like the mids and the mid bass to high bass
Jul 2, 2012 at 1:46 PM Post #139 of 204
I was linked to this thread via PM, saying there's links in it somewhere to a study on equalizing all headphones to sound the same, looks like this was it.
Back to the subject:
Take a look at these papers:
http://www.cpt.univ-mrs.fr/~briolle/11thAESpart1.pdf
http://www.cpt.univ-mrs.fr/~briolle/11thAESpart2.pdf
Even with a 200-tap FIR filter @ 44.1 kHz, which is of a rather poor quality, the author was able to match the sound quality of a poor quality headphone to that of a high quality headphone subjectively. Thus, in conclusion, as long as the filter is not a linear phase(pre-ringing) & there's no excursion issue, you can freely equalize headphones however you see them fit.
Looking at it now...
From what I can tell, they used a STAX Lambda Pro to simulate other headphones, and asked the participants to rate the sound quality subjectively.
They then compiled the ratings, and found that the averages were well correlated to eachother, so the perceptions of the simulations by the participants were fairly uniform.
In the conclusions section (second document) it says "One most important results of this study is the finding that the quality of a headphone of poor or fair quality can be considerably improved simply by simulating on it the acoustical characteristics of an excellent headphone".
Which headphone did they use of poor or fair quality?  I'm trying to read all of it, and I can only see reference to them using a single headphone in the whole test, the STAX Lambda Pro.
Jul 2, 2012 at 1:54 PM Post #140 of 204
Yeah the MDR-SA5000 doesn't seem like a good choice for flat (HE-6) and deep bass. Not only would boosting bass cause a lot of distortion, it seems like it's too open to "contain" the pressure. The other way around would be much easier and yield better results.
Is the HE-6 considered very flat?  I've heard the HE-6 and I do think it's a very "reference" sounding headphone, and sounds totally different to the SA-5k.
Intuitively, I think you could make the HE-6 sound fairly similar to the SA-5k with EQ, but making either of them sound like the HE60 would be impossible, since that has the most spacious crazy soundstage I've ever heard, unless you're going to emulate that as well, but it's certainly not in the FR.
Jul 2, 2012 at 2:45 PM Post #141 of 204
The HE-6 doesn't seem to have huge nulls, seems relatively smooth in the FR (except for a small discontinuity @ 5K based on Tyll's plot), and it does seem fairly flat relative to other HPs (after HRTF compensation).
Based on Tyll's plots, I think making a SA-5k sound like an HE60 would be difficult (lots of high freq nulls, positional variation, and THD with the Sony). However, equalizing an HE-6 to sound like an HE60 might give you a pleasant surprise
Jul 2, 2012 at 3:47 PM Post #142 of 204
The HE60 made me look at it like it has some trick up it's sleeve, the technology somehow makes the soundstage quite unusual.  A parametric EQ doesn't affect soundstage very much IME.
For the same reason, I can't imagine turning the Edition 8 into the HD800 either, since one is closed sounding, and the other is very open-air sounding, with the drivers physically farther away from your ear, in centimetres.
The physical distance of the driver from the ear, surely can't be emulated with an equalizer.
Jul 2, 2012 at 4:15 PM Post #143 of 204
Surely you are wrong.
Jul 2, 2012 at 4:49 PM Post #145 of 204
How much success you have probably depends on the capabilities and limitations of the particular equalizer you are using. But distance perception can be manipulated through equalization.
Jul 3, 2012 at 1:37 AM Post #147 of 204
Based on Tyll's plots, I think making a SA-5k sound like an HE60 would be difficult (lots of high freq nulls, positional variation, and THD with the Sony). However, equalizing an HE-6 to sound like an HE60 might give you a pleasant surprise :smile:
I can say for a fact that the HE-6 is an amazing chameleon. With EQ I can make them sound like just about any other planar I've heard. For example, setting them to sound like LCD-2s or 3s is a piece of cake.
Jul 3, 2012 at 12:03 PM Post #148 of 204
Very true and one of the reasons I have always liked and recommended the HE-6. It responds extremely well to EQ - something that the Audeze's don't do as well.
Out of the right rig with a good parametric, you can get the HE-6 to sound like an electrostat like the SR-007. The HE-6 is mighty fine headphone.
Jul 3, 2012 at 11:59 PM Post #149 of 204
There seems to be a thing that  is hard to emulate, though not because equaliser can't do that, but because there are no measurements of it. Ear canal resonances seem to be very dependent on headphone's acoustic impedance and it's one of the things that seem to mess with soundstage seriously. HE60, being an open electrostat, seems to have low impedance as sound can pass through the membrane. HD800 should have quite low impedance due to ear chamber construction with the grilles. Most of the other phones, however, have much higher impedance and offset the sound much more.
