BrokeAudiophileMan
Hi folks, I have a lot of full sized headphones but I've never done anything about ear pad care and I feel like that's a bad move on my part. What products do I need?
I'm most concerned about my Momentum 4 which I've had since the end of February and get heavy use. The earpad material is protein leather as far as I know. Noticeably less smooth soft and supple than they used to be and I worry the pads may crack.
When I used to ride a bike my leather gloves were something I always moisturized to keep them supple so they wouldn't crack. Can I do something like that for headphones?
I'm also concerned about the earpads on my Bathys but those are still mint. Had them for the same length of time as the Momentum 4. The Bathys pads are leather though.
Help?
Help?
